Fixed my CM5 overheating problem with a riser and a thin thermal pad
We all know that the uconsole dissipates heat from the back of the handheld by going through a super thick thermal pad. I knew that the thermal pad was a bad idea but didn’t know how much (or how to solve it.)
I found a device called a “CM4 Adapter, Interface Protection Adapter Board for Raspberry Pi Compute Module 4 Lite/eMMC, Physical Protection for Frequent Plugging and Unplugging of CM4 Socket” (that’s the listing name on amazon) or " Protection Adapter Board for Raspberry Pi CM4, for frequent plugging" (the listing title on pishop.us) which is basically a board with a male CM4 port on one side and a female on the other. It lifts the CM5 but still fits.
The good news is that it fits and gives good pressure to a 0.5mm thermal pad! I may even replace it with thermal putty. The heat is going directly from the cm5 into the back of the case and my temperatures went down from "70C and throttling with two incidents of hard shutdown) to “55C max, while GCC compiling box86.”
tl;dr: try to get a better heat transfer from your CM5 to the back of your handheld.
This is an interesting concept.
Right? The problem was obvious (the thermal pad wasn’t conducting heat fast enough out of the cpu so turned into a hot spot) but the SOLUTION was unexpected. I don’t even remember why I bought the CM4 riser from Waveshare. I stumbled across it again after my CM5 heat problems and thought “Why not?”
What I would really love is a board just like this, except it has breakout pads or ribbon cable connectors for some of the CM4/CM5 lanes that aren’t available to the uconsole board. Now that we know the board will physically fit, we can design other boards with better features.
I did use washers on every corner (between uconsole riser and the CM4 adapter, and then the cm4 adapter and the CM5) and everything seems plenty stable.
I just ordered one. Did you use the washer to stabilize it and keep it from being compressed to much?
Yes exactly, @TechSR2
The washers I got were from a totally different order: from heat sink sets for CM4 boards. They worked perfectly.
Thanks for sharing! Ordered one :slight_smile:
I hope it helps you and more people. I don’t know if others will get the same results I am getting, but it’d be nice to see such a simple solution to a dramatic heat problem.
Also, knowing that this riser physically fits will allow uconsole accessory developers to use sandwiched boards like this to tap into unused cm4/cm5 features.
How hot is the back of the case getting?
Mine running full bore for an hour and a half, the back of the case will get to 72c at the hottest spot. I’m talking CPU and GPU maxed.
Never thought waveshare would make this thing…
Also please beware of Low-temperature burns, 55c will definitely cause that.
This worked great and fixed my issues, though I replaced the pad that was directly touching the CM5 to be some thermal-paste instead, since it was bending out the back-pannel by just the tiniest amount.
Great to hear! Oh yes absolutely get rid of that winter coat of a thermal pad that came with the uConsole if you use a riser. I am using a 0.5mm pad I think. Maybe 1.0? I have some thermal putty that I may use. Still considering it.
have you considered thermal epoxy???
Epoxy? Like cementing my CM5 to the backside of my the inside of my uConsole? That would work exactly once, then you open up the uConsole and it tears out the CM5. :smiley:
but there is a connection board for extra decouple point! :nerd_face:
Saw this and ordered it. put it together and yes it stays way cooler.normal usage at 45c, nice little hand warmer. Thanks for sharing!
I’m in the early stages of designing a breakout board like that, including fan control for better cm5 heat control. Would require a redesigned backplate but i’me also working on that. Will update you as it goes.
When introducing the cm5 module, the question of how to solve the heat treatment problem arises, but are there any other optimal solutions?
Still waiting for mine to arrive, but wouldn’t a copper strip/slab be an easier solution?
This was actually my initial idea when I was building my uConsole. I purchased some copper bar stock and messed around with it but ultimately scrapped the idea and just used smaller copper shims/heatsinks instead. Found the proper thickness shims that allowed for the thinnest heatpad to be used (I think I had .5mm thermal pads) and that worked good enough.
Since the chips on on the CM4 are different heights, it was easier to find the proper height of the smaller copper heatsinks and then have the .5 thermal pads then it was to have a thicker, larger, even thickness copper bar and varying size thermal pads to make up for the height difference.
I tested it with an OCed CM4 running some pretty process heavy apps and it was cool and stable for hours.
Now that im planning on sticking a CM5 in my uConsole, I have been thinking about revisiting my initial idea…
