I can’t work out if I’m just being an idiot here but I can’t work out how to assemble the screen to the mainboard. If I do it as set out in the instructions, the cable won’t go into the slot. If I do it so the cable fits into the slot then the modules are misaligned. And yes, I’m bending the cable on itself inside the screen case as instructed.
Either I’m being dim or the cable is the wrong way round, is it just a case that the mainboard cable was plugged in upside down when it was originally assembled?
Same here. I just got mine today and have the same problem. That’s because the ribbon connecting the mother board and the screen is upside down. Most likely this batch’s ribbons were placed upside down.
I can confirm that my ribbon was reversed too. I spent a long time trying to force the connector in until I decided to try unplugging it from the screen and plugging it back in the other way around. It works perfectly now!
Thanks for the help! The only problem is that the screen has an orange line with a two rows of dead pixels. I was just wondering if you guys have that too.
Hello. I am new to clockwork and I just got mine. I have been having the same problem. If possible, do any of you have an image of the clockwork that works with the cable flipped? Thanks.
Pull the two grey tabs towards the cable, they will click open and you can pull the ribbon out, turn it around and push it back in. Then push the tabs back in until they click.
