Valssu
February 17, 2019, 5:20pm
1
Hah, after updating the system via setting, the system shows me the loading screen all the time.
Well, after triggering something via SSH, I totally fucked up the system: after the CPI screen, there is only a black screen.
BTW, I cant locate the ‘launcher’.
So, maybe I should reinstall the system? How to do that via SSH? And, will I lose my pico-8 and saved data in retroarch?
guu
February 17, 2019, 5:45pm
2
your pico8 zip is in your PC right? if not
try to use winscp(use the cpi:cpi ssh account to login ) to copy the pico8 out of GS
but I remember that if you buy a pico8, you will have a download link in your email
so basicly , there is no need to worry about pico8,wont let you buy again
and the data in retroarch can be found and setup again because retroarch is opensource
here is the os image
use dd(linux) or win32 disk Win32 Disk Imager download | SourceForge.net
to do the it ,flash the image into a TF card ,8G space Minimum
Valssu
February 17, 2019, 5:49pm
3
Neat.
Another thing, the major issue I am having now is that I cant find the launcher.
So I tried “git clone https://github.com/clockworkpi/launcher.git ”, still loading now. Is that a proper way to do it?
guu
February 17, 2019, 5:51pm
4
the launcher maybe in /home/cpi/apps/ since v0.2, we move the launcher out of /home/cpi/apps
and if you did the git clone
there is still a problem is bluetooth ,if your os image is v0.1 ,there is no bluetooth and it will cause the launcher fail to start
so the simple way is to reflash the tf card
Valssu
February 17, 2019, 5:53pm
5
Yeah, I saw these from another post.
Damn, the size of the OS is huge! Any tutorial of flashing the image? I am using a Mac.
But anyway, thanks mate
guu
February 17, 2019, 6:00pm
6
mac? that’s even easier than linux
just download the clockworkos_v0.21.img.bz2 and unzip it( take a little long time but not hard for mac)
and mac has dd ,but I have not used mac for many years so I can not remember whole command line would be
in linux
usually is
dd if=clockworkos_v0.21.img of=/dev/sdb bs=4096
the /dev/sdb is the device identification of the TF card, usually
I can get it by
dmesg | tail
when I plug the TF card in , the mac can do this ,too,but I can not remember how and which
For mac
I think command line is not the first choice
There must be a GUI tools can do the dd job
try disk manger
there is no big risk ,you just need to look out be carefully chose the disk you are gonna do ,do not choose the main HDD of mac os
Valssu
February 17, 2019, 6:03pm
7
Cheers. Will have a try.
BTW, why the ssh is very slow? Any reason? Something wrong with my Mac?
guu
February 17, 2019, 6:06pm
8
Not at all,you mac is fine
We did not realize the problem until one of us in this community find out that,
the linux system of GS has wif power save on by default and it casue the lower speed of WIFI (ssh)
and in the later os image, launcher has fixed it
Valssu
February 17, 2019, 6:07pm
9
Gotcha. BTW, should I move tha ‘launcher’ from /apps to the default direction?
guu
February 17, 2019, 6:12pm
10
move the launcher is not enough to fix your gs right now,
if you flashed the os image ,lanuncher will be in the new location
Valssu
11
OK, so I have to download them now. Cheers mate. Hope next update is less troublesome…
Valssu
February 17, 2019, 6:18pm
12
A small question, mate: any recommendation for learning linux? It seems that I need to learn some Linux to make the full use of game shell.
On the Mac, command line is the easiest way. First enter diskutil list to find your memory card. Look for the card and its number on the right (diskX). Ignore the partition numbers, they will be wiped. Then unmount the card and proceed to copy to it:
diskutil umountDisk diskX
dd if=~/<path to folder>/clockworkos_v0.21.img of=/dev/rdiskX bs=4m
Replace the X with the disk number from the diskutil list command.
eoiue
February 18, 2019, 8:44am
14
https://linuxjourney.com/
Really well put together website.
