Using my GameShell with my Mac introduced all sort of small “backup” files into every directory accessed through SMB. I searched the internet for a technique to recursively delete them through SSH. I came across a PowerShell script to do just that! Now my problem was how to get PowerShell into the GameShell! Not too difficult thanks to instructions from Microsoft. Rather than your having to search yourself, I’ll present the details here.
Install the Raspbian Variant
# Install prerequisites
sudo apt-get install libunwind8
# Grab the latest tar.gz
wget https://github.com/PowerShell/PowerShell/releases/download/v6.1.1/powershell-6.1.1-linux-arm32.tar.gz
# Make folder to put powershell
mkdir ~/powershell
# Unpack the tar.gz file
tar -xvf ./powershell-6.1.1-linux-arm32.tar.gz -C ~/powershell
# Start PowerShell
~/powershell/pwsh
Optionally you can create a symbolic link to be able to start PowerShell without specifying path to the “pwsh” binary
# Start PowerShell from bash with sudo to create a symbolic link
sudo ~/powershell/pwsh -c New-Item -ItemType SymbolicLink -Path "/usr/bin/pwsh" -Target "\$PSHOME/pwsh" -Force
# alternatively you can run following to create a symbolic link
# sudo ln -s ~/powershell/pwsh /usr/bin/pwsh
# Now to start PowerShell you can just run "pwsh"
Uninstall PowerShell
rm -rf ~/powershell
Clean Script
Now, with PowerShell installed, we need the script to clean our directories. Using nano, we can paste the script and save it as clean.ps1
$curDir = Split-Path -Parent $MyInvocation.MyCommand.Path
foreach ($file in Get-ChildItem -force $curDir -Recurse)
if (($file.Extension -match '.DS_Store') -or ($file -like '._*'))
Remove-Item $file.FullName -Force | Out-Null
With PowerShell running execute the script from our home directory:
cd ~
pwsh
PS /home/cpi> ./clean
PS /home/cpi> exit
That’s it! I’m sure there can be a lot of additional uses for PowerShell in our GameShells.
EDIT: Unfortunately, there’s a bug in the above script. It just doesn’t work. I know PowerShell is working because the command…
PS /home/cpi> Remove-Item ~/games/4DO/._* -Force
…worked perfectly.
I will work with it to try to find the error. If anyone else can spot it, I’d appreciate a heads up.
