Took some effort and tore one but a huge improvement when on hard surfaces, still locks too. Silicon sleeve, various colours available. Finger grease helps the sleeve slide yet a piece of cloth is needed to grip it and slowly push/pull. Be careful of the wire ends ripping the sleeve, be patient, keep it straight as it goes onto the wire or it will tear !
Yes, this is very much a needed mod. What thickness tubing did you buy? I want to order some.
too bad that it won’t fit with the antenna mounts, I’m planning to make a new printed design, but I have been too lazy
Just pulled a suitable size from an old box of tubing sorry, you can measure the diameter of the stand metal tho…
Nice !. A small gap in the middle helps the lock action tho…
@DigitalDreams, as I’m still waiting for my uConsole, I can’t measure it myself. Could you please tell me what the diameter of the steel bracket is? Thanks!
2.5mm (measured with a micrometer)…
Thank you very much!
