Oof, was that damaged in transit? Looks like it’s taken a nasty whack.
Can you post a clear picture of the pads on the board? If they’re intact, it’s an easy fix: new DIP switch, quick bit of solder. If they’re damaged, it gets trickier…
Looks like cold solder joint, fortunately you can resolder it, also thats not such a critical piece so you can just bridge the setting you wish it to be and leave the other disconnected.
Considering that two of the pad has been torn off, it is not a “weak” soldering there but more of a hit on that switch…
