I’m trying to install multiple kernels and switch between them by changing config.txt on my CM4 DevTerm. However, I can’t get it to boot if I change the kernel to anything besides the default. Here’s what I’ve tried:
- Add the line
kernel=kernel8.imgto config.txt. This works fine. - Copy kernel8.img to kernel_copy.img. Change config.txt to
kernel=kernel_copy.img. This fails to boot. - Try scenario 2 again, but this time also copy initramfs8 to initramfs_copy.img, just in case it autodetects the name like that. No change.
- I’ve also tried compiling my own kernel and installing it to kernel_mine.img, as suggested in the Raspberry Pi kernel docs. It fails in the same way as 2, of course.
I have UART logging enabled for the bootloader and kernel. Here’s what the logs look like for scenario 1:
RPi: BOOTLOADER release VERSION:4fd8f1f3 DATE: 2023/05/11 TIME: 07:26:03
BOOTMODE: 0x06 partition 0 build-ts BUILD_TIMESTAMP=1683786363 serial 6cc3ffaa boardrev c03140 stc 478856
PM_RSTS: 0x00001000
part 00000000 reset_info 00000000
uSD voltage 3.3V
Initialising SDRAM 'Samsung' 16Gb x2 total-size: 32 Gbit 3200
DDR 3200 1 0 32 152
Boot mode: SD (01) order f2564
SD HOST: 200000000 CTL0: 0x00800000 BUS: 400000 Hz actual: 390625 HZ div: 512 (256) status: 0x1fff0000 delay: 276
SD HOST: 200000000 CTL0: 0x00800f00 BUS: 400000 Hz actual: 390625 HZ div: 512 (256) status: 0x1fff0000 delay: 276
OCR c0ff8000 [23]
CID: 006f0303434241445310aa0000830173
CSD: 400e00325b590000ea6d7f800a404000
SD: bus-width: 4 spec: 2 SCR: 0x02b58003 0x00000000
SD HOST: 200000000 CTL0: 0x00800f04 BUS: 50000000 Hz actual: 50000000 HZ div: 4 (2) status: 0x1fff0000 delay: 2
MBR: 0x00002000, 1048576 type: 0x0c
MBR: 0x00102000,60397568 type: 0x83
MBR: 0x00000000, 0 type: 0x00
Trying partition: 0
type: 32 lba: 8192 oem: 'mkfs.fat' volume: ' bootfs '
rsc 32 fat-sectors 2040 c-count 261116 c-size 4
root dir cluster 2 sectors 0 entries 0
FAT32 clusters 261116
Trying partition: 0
Read config.txt bytes 337 hnd 0x292e
gpio_cmd: '10=ip,np' pins: 10-10 drive: -1 fsel: 0 term: 0
Read start4.elf bytes 2254208 hnd 0x4ca5
Read fixup4.dat bytes 5403 hnd 0x129
0x00c03140 0x00000000 0x00001fff
MEM GPU: 76 ARM: 948 TOTAL: 1024
Firmware: 03dc77429335caee083e22ddc8eec09c07f12a7a Aug 10 2023 15:33:38
Starting start4.elf @ 0xfec00200 partition 0
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd083]
[ 0.000000] Linux version 5.10.17-v8+ (cpi@cpi-X79) (aarch64-linux-gnu-gcc (Ubuntu 11.3.0-1ubuntu1~22.04) 11.3.0, 3
[ 0.000000] Machine model: Raspberry Pi Compute Module 4 Rev 1.0
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000016c00000, size 384 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000000000-0x000000003fffffff]
[ 0.000000] DMA32 [mem 0x0000000040000000-0x00000000fbffffff]
[ 0.000000] Normal empty
[...and this continues on and shows the whole boot sequence up to the login screen...]
And here is scenario 2. It seems like the bootloader passes off to the kernel, which never prints its first log.
PM_RSTS: 0x00001000
uSD voltage 3.3V
DDR 3200 1 0 32 152
OCR c0ff8000 [18]
Trying partition: 0
Trying partition: 0
Read config.txt bytes 317 hnd 0x9
Diff of the two logs (up to the point where the kernel boots):
@@ -9,7 +9,7 @@
-OCR c0ff8000 [23]
+OCR c0ff8000 [18]
@@ -28,7 +28,7 @@
-Read config.txt bytes 337 hnd 0x292e
+Read config.txt bytes 317 hnd 0x9
Any ideas on what could be going wrong? Maybe something needs to be configured with the initramfs images as well?
