I followed the instructions at How to use the 4G extension · clockworkpi/uConsole Wiki · GitHub but I am unable to get past sudo nmcli c up 4gnet as instead of a new interface I get timeout. Also, I am unable to scan other networks (not sure if the command is supposed to work though):
mmcli -m 0 --3gpp-scan
error: couldn't scan networks in the modem: 'Timeout was reached'
Uconsole with LTE module from clockworkpi, cm4, stock antenna (plugged as per assembly manual). Any idea?
Most people don’t use the 4g I think, bought with FOMO and then it sits unused because there are other expansion cards out there now that don’t require paying for a second sim card.
So not as many people reporting those issues, but the physics don’t really change, so I assume it has similar issues
