Hi,
I noticed that the board has a “USB-C port for flashing: can be used to flash the eMMC version computer module.”
Does this mean I don’t need a developer board to flash the eMMC module?
Also, is there any documentation on how to use this port for flashing?
Thanks!
vileer
2
Yes, you don’t need another IO board to flash it. Just put the position #1 of the dip switch to ON.
Then connect the adapter board’s USB-C port to your computer and follow this article to flash it.
Thanks for quick response. What is the purpose of the switch #2?
vileer
4
Lock the CM4/5’s EEPROM (kinda like a BIOS for the PC) so it can’t be flashed.
Hi Vileer, can the CM5 be flashed on the adapter board without it being installed in the uconsole?
