Custom D.E.O.T. V1.0+/Clockwork OS v0.4 image - With Updated Kernel 5.3.6, Latest Lima Drivers, RA1.8.1, Mupen64+ and much more! (Current version: 191122)
HOLY COW THIS IS PERFECT! The fact that you’ve gone to the trouble to explain exactly how and why things are done - this is how communication and progress is made! Thank you so much!
Is it okay for me to provide your image on the download lists for this image; since it’s based on the custom image anyway? I love your work, and will certainly be applying it as a standard!
The 191111 image would just be a cleaner slate to work from, since none of the Lima/Mesa changes have been made; just to rule out any other potential problems that can occur.
Re: MPD deprecation, here’s the modification I made to mpd.conf. Nothing fancy; just commenting out deprecated Unicode sets, and disabling tidal and qobuz and all associated tokens. I doubt the CPI would be able to output adequate audio to really leverage Tidal anyway.
music_directory		"/home/cpi/music"
playlist_directory	"/home/cpi/.mpd/playlists"
db_file			"/home/cpi/.mpd/tag_cache"
log_file		"/home/cpi/.mpd/mpd.log"
pid_file		"/home/cpi/.mpd/pid"
state_file		"/home/cpi/.mpd/state"
sticker_file		"/home/cpi/.mpd/sticker.sql"
user			"cpi"
bind_to_address		"/tmp/mpd.socket"
auto_update		"yes"
auto_update_depth	"2"
input {
        plugin "curl"
audio_output {
	type	"alsa"
	name	"ALSA Device"
audio_output {
	type	"fifo"
	name	"my_fifo"
	path	"/tmp/mpd.fifo"
	format	"44100:16:2"
filesystem_charset	"UTF-8"
# id3v1_encoding		"UTF-8"
# QOBUZ input plugin
input {
        enabled    "no"
        plugin     "qobuz"
#        app_id     "ID"
#        app_secret "SECRET"
#        username   "USERNAME"
#        password   "PASSWORD"
#        format_id  "N"
# TIDAL input plugin
input {
        enabled      "no"
        plugin       "tidal"
#        token        "TOKEN"
#        audioquality "Q"
# Decoder #####################################################################
decoder {
        plugin                  "hybrid_dsd"
        enabled                 "no"
#       gapless                 "no"
As for recompiling mupen, I’ve actually left the dependencies in the home directory under ~/.mupen. There a script to install them in the home directory called mupen.sh.That should be all you need to get mupen working, besides maybe fiddling with the config file and/or action file; specifically specifying which output to use. I think that was a problem people had early on in the mupen/gameshell days.
