Custom D.E.O.T. V2.0+/Clockwork OS v0.5 image - With customised DEOT interface, Kernel 5.7, Optional 1400MHz OC, Debian 10 Buster, Retroarch 1.9.0, Mupen64+ plus more! (Current build: 200903)
Hi,
I made a note in the first post regarding flickering. Did you apply the patch?
Hi,
How do I come to know if my cores got updated? It run the updater and it does say cores up to date (or something similar).
But how do I manually verify this?
I didn’t want to go silently benefitting from all the hard work in here, so hiii :grin: I lost patience with my setup on OS 0.4 and figured I’d try this. I flashed your 200903 build and set everything up, and at first my machine was flickering like a few others have reported (for me it was scanlines jittering a handful of pixels left and right). I swapped in/out about every combo of clock setting and kernel provided in the menus…no dice. Weirdly enough, if I kept the unit powered on, the flickering would go away after about 10 minutes. After getting tired of that(!) I tried your patch. It’s been solid for over a week now playing GBA, GBC, MAME, PSX, Neo Geo Pocket, Atari 2600 images, running Pico-8, and even running a couple of flavors of UAE. If I run into any issues I’ll speak up, but it’s been solid so far.
Thanks for all the work you do in here on the forum. I honestly can’t remember the last time I saw someone put this kind of help together and consistently help others with just about anything. Also, thanks to those putting together custom kernels and apps. And thanks to those talking through issues here. It’s silently helped my Gameshell be waaay more enjoyable than it was. I really appreciate it!
This is such a beautiful reply!! I honestly don’t know if half the things work for everyone. Most people who reply only do so when something doesn’t work. Great to hear that everything is working, including the patch for the flickering! :slight_smile:
I’ve been a bit busy with life lately, so haven’t had as much time to help as much. But it looks like most of the posts here are directed at the devterm.
Fingers crossed most of the ā€œregular user issuesā€ have been addressed, and we now have a fairly feature rich gameshell device, free from most problems!!
I haven’t been through the entire thread since there’s a lot. But I managed to mount the image, use the patches preemptively to fix flashing (if I were to even have it) and so far things seem to be running smoothly for me. Transferring over a bunch of my GBA/GB roms to test out retroarch on this image. Not sure if I’ll have to reference another thread for the settings I used to have. Either way I am impressed I managed this so far with 0 issues.
There’s a lot I need to learn still, but so far so good.
If there are any parts of the thread I should read, please can you link me to those spots? Thanks in advance and awesome that there’s some people here to help/create.
HDMI output does not work.
The first screen appears, but it does not proceed to the menu screen.
I am using the latest custom image (200903).
If anyone knows how to solve this problem, please advise.
Hey, thanks for the feedback!
It sounds like you should be all good. I’ve tried to take all things into consideration, and put any specific instructions into the first post.
Fingers crossed things all work!
@misaki860 are you booting up with the HDMI plugged in? Give that a shot. Otherwise, try a different kernel out, using the kernel switching scripts.
For some reason, the wonderswan emulator specified an extension only for the color version, you need to fix it and add ws
/home/cpi/apps/Menu/20_Retro Games/45_Wswan/action.config
ROM=/home/cpi/games/WSWAN
ROM_SO=/home/cpi/.config/retroarch/cores/mednafen_wswan_libretro.so
EXT=ws,wsc,zip,7z
LAUNCHER=retroarch -L
TITLE=Wswan Roms
SO_URL=https://buildbot.libretro.com/nightly/linux/armv7-neon-hf/latest/mednafen_wswan_libretro.so.zip
My game shell turns off itself after a few minutes of standby, is there a way to keep it awake?
@javelinface when are we gonna see a custom 0.6 :wink:
I havent been here in a long while myself, any updates to DEOT? also considering a uConsole instead of devterm for now
Set the power to server under Settings - > Power
I have 2 main issues, I don’t know if they are software or hardware related.
  1. Battery is draining while device is powered off
  2. Wi-Fi and bluetooth stop working after a while. Scanning for wi-fi networks and bluetooth devices not working.
After clean install of Deot image wifi & bluetooth starts working.
Hello I like your DEOT theme a lot I just have one small question about the ā€œscanlinesā€ effect on the screen, which looks great however it keeps the effect on in OhBoyand I was wondering if tehre was a way to turn that off for certain games or not. I noticed its not there for SNES and GBA games I tried and they ran well.
EDIT: okay , I found the flickering fix in your original post, did not see that before, and i ran the commands and it appears to be fixed.
I’ve scanned this post and did some Googling, but I’m stuck on adding ROMs for a few systems.
But before I go into that, this build is AWESOME. Looks cool, and generally works so well. I’m really happy to have it, so THANKS!
  1. Pico-8 - I bought and copied over Pico-8 for the Pi but it tells me it’s not installed. I had the same problem with the original OS, too. There was a home/games/PICO-8 folder already present, which is where the error I’m getting says to put it…
  2. GameGear - There was a folder existing for these, as well, but the OS tells me the ROMs location is empty. I tried GGEAR, GEAR, gg, GameGear, and GAMEGEAR as folder names - so I’ve tried the default that the install put on my SD card but also some variations I’ve found in various articles, but nothing seems to work. I wonder if there’s a BIOS file missing, but I’ve found no folder where it seems like BIOS images should go.
  3. UAE - same issue as the gamegear, and also wondering about a BIOS location here as well (for the kickstart rom I have, I would imagine)
  4. TG16 - there’s no menu entry for the TG16 but surely the machine can cope with that. I added some cores in retroarch for it, but see no way to add a menu item in the nav for it. Is that possible? Or do I need to get to the TG16 some other way?
I had a similar issue with Pico-8 on my Debian powered iMac and came across this page when looking for a fix my problem. Running PICO 8 on the GameShell Ā· clockworkpi/GameShellDocs Wiki Ā· GitHub
That fixed the pico. Thanks!
Any ideas on uae or gamegear? They have folders and menu entries but keep telling me to send files over via wifi. All the other emus are just fine.
And any leads on how I might add menu entries for the 2600 and tg16? Seems odd those are missing altogether.
I can use this script to switch to TWM, but I don’t have a bluetooth mouse, i only have a bluetooth keyboard connected, and after press clt-alt-t the opened xterm is not in focus, how can i switch focus between windows in TWM by only use keyboard?
Thank you for your work and support on this project. I’m new to this technology and my Gameshell recently stopping booting up properly. I thought I would try updating/downloading a new OS and was able to download and flash your program but now my system has been turning on and rebooting repeatedly. I understand in your ā€œpost-installationā€ instructions that multiple reboots is normal and to have patience, but I’m worried I may have had a misstep. Any advice? Thank you.
