If you use Trixie (not sure about others), you can use the Raspberry Pi Imager right from the OS with the SSD installed in the uConsole. Then you use Raspi-config to set your boot drive to the SSD.
The boot order was set by the computer module’s EEPROM. You can use raspi-config like @Toml_12953 said, or use rpi-eeprom-config to configure the boot order.
In option #2, once you flash the SSD and install it back into the uConsole, it will automatically boot from it if it’s the first option in your boot order.
Thanks! To all of you… will try it out when the upgrade kit arrived
Thank you! really a left movement by about 9mm then.
appreciate the info! just to confirm…
This is moving to the left with the back plate facing up right? i.e. moves nearer to the audio port and away from the expansion slot.
IK believe you should be able to use the linux dd command to copy direct from your old memory (mine is a sd card) to the nvme once you have it installed, then you can configure the uconsole to boot from the nvme instead of the sd card.
Yes, back plate facing up.
Sdcopy from SD card to NVME, I am guessing
is there anyway I can purchase it from my poor country Vietnam? ![]()
We use a freight forwarder service to ship the packages, I will ask them if they could ship to Vietnam.
Is anybody from HackerGadgets here in the forum?
I have my top spec Radxa waiting to go in.
I ordered every part they were offering quite a while ago.
Can anyone advise please?
Get a friend to buy it and then mail it to you… ![]()
it’s a preorder like the description says, and the original estimated ship date was the 30th of november, but I think vileer has said there were some delays for some versions so they are pushed back like 2 more weeks
June 11th? Or November 6th? I hate that mm/dd/yy and dd/mm/yy are so easy to mix up lol.
Guessing November 6th since they went on pre-order in October. Anyway, it’s a “pre-order”. it wasn’t ready to ship when you bought it. They are shipping soon.
Ordered on 6th November 2025.
Gotcha. Figured it couldn’t have been July lol. The shipping notice on the product page might help answer your question, though.
If I order now, would I be able to get it on December? If I select UPS for shipping it still says preorder and on the page it says November 30 ?!
ANY Updates and shipping of the HackerGadgets update boards for the uconsole?
@bfpa40 @Sherlock_XGP @Richard_Castro We are now packing the order without the AIO v2,the antenna mounting kit, and the Radxa CM5, and packing hundreds of orders is taking longer than I expected. The orders for AIO v2,the antenna mounting kit, and the Radxa CM5 will be packed and shipped after 15th Dec.
Okay,
Sorry to bother I just notice you said this on the Very top lol ![]()
Thanks for the update
