RetroArch Megathread
Hi everybody!
Today I flashed a new SD card and I’m trying to reinstall Retroarch from this guide. Mind you, I had already done that successfully on the original SD card. But this time, when I execute:
I get a lot of 404 errors like this:
E: Failed to fetch http://security.debian.org/debian-security/pool/updates/main/f/ffmpeg/libavdevice-dev_3.2.10-1~deb9u1_armhf.deb 404 Not Found
And at the end:
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
E: Failed to process build dependencies
What should I do?
I still can’t get
sudo apt-get build-dep retroarch
To work. It shows a bunch of 404 errors in the Terminal. I’m guessing due to that this line doesn’t work either:
./configure --disable-vulkan --disable-ffmpeg --enable-xmb --disable-materialui --disable-flac --disable-parport --disable-vulkan_display --disable-videocore --disable-videoprocessor --disable-v4l2 --enable-x11 --disable-wayland --disable-vg --disable-jack --enable-kms --disable-discord
It says that KMS is not available.
Is the server down @fr500?
@uke run this first:
sudo apt-get update
then start over with
thanks wohali!
works now.
I know this is quite old, but if any one is having issues to get 60FPS for PCSX-rearmed on the gameshell.
Here is a recompiled .so that is compiled on the gameshell, I was able to reach 60FPS for Mega Man X4, the Core Updater .so only managed to get 22fps.
Just copy it under ~/.config/retroarch/cores/ and load it in retroarch and enjoy smooth gaming.
This is great, I was having that issue and could only make it work via the standalone. Will try this later.
@fr500 the link to your files is broken. I need to download your gPSP because the one on buildbot is broken
Any chance you’d be into working on a gpsp_libretro.so that will work!?
hey
well… I got quite disappointed at the lack of solutions for GPU acceleration so I haven’t really used my GS too much.
That said the easiest thing to do would be to build it! I think building it in the GS itself yields the best results.
Anyway I’ll check this weekend.
I’m willing to try my hand at that, I just don’t know enough to do so. Im currently reading primers lol
If I build it on the GS, I don’t know how to make the .so library from the .c and .h files.
git clone https://github.com/libretro/gpsp
cd gpsp
make -j 2
Thanks man. The build was a success! I was however unsuccessful in it running. Same old crashing.
Whenever you have some time, if you could take a peek I’d appreciate it. I can’t tweak it because I don’t know about any of that stuff.
Uhm … I think that 0.21 have lima driver integrated:
Did anyone succesfully install a Sony PSP emulator core and would be willing to do a write up ?
XMB kills the battery real quick I think, as well… but it is damn sweet.
Bumping this thread also for picodrive libretro core:
alright so there is a new image, gonna try it out, adjust and maybe build mupen/ppsspp :stuck_out_tongue:
aaaaand… not gonna happen, doesn’t even allow XMB with lima so PPSSPP will not work
so I configured with these parameters now:
./configure --disable-vulkan --disable-ffmpeg --enable-xmb --disable-materialui --disable-flac --disable-parport --disable-vulkan_display --disable-videocore --disable-videoprocessor --disable-v4l2 --enable-x11 --disable-wayland --disable-vg --disable-jack --disable-discord --disable-langextra --enable-mali_fbdev
make && sudo make install
then I ran this on ssh:
sudo usermod -a -G input `whoami`
Then I changed my drivers to:
  • input: udev
  • joypad: udev
  • video: gl
then I run
sudo chvt 2
retroarch
Now it’s using mali, but it’s inconvenient to say the least.
This is all with cores from the RA updater:
  • Beetle NeoGeo Pocket is full speed now (it wasn’t before), it has a weird issue with some stuff being cut out of the frame though
  • mGBA is full speed (it skipped frames before)
  • snes9x mainline is fullspeed
  • gpgx is not fullspeed
  • pcsx rearmed: sloooooow, not built with neon, gotta build it proper
  • picodrive crashes, gotta build it properly I guess
ok, I’ll post a small guide on building cores, so hopefully someone will make a repo of cpi enhanced cores:
always run this first:
export TARGET=~/.config/retroarch/cores/
mkdir -p ~/repositories/cores
picodrive working perfect, full speed on sonic 3
cd ~/repositories/cores
git clone https://github.com/libretro/picodrive.git picodrive
cd picodrive
git fetch origin && git reset --hard origin/master
git submodule update --init
make -f Makefile.libretro -j2 platform="armv neon hardfloat"
cp -v *.so $TARGET
pcsx_rearmed working perfect, full speed on ridge racer type 4
git clone https://github.com/libretro/pcsx_rearmed.git
cd pcsx_rearmed
make -f Makefile.libretro -j2 platform=classic_armv7_a7
cp -v *.so $TARGET
