Hi! Will check tomorrow, have not tried the filters yet, other than following the guide for retro arch setup. Unsure if any are running. Will let you know !
Just do what the guide says
So from the RetroArch repo do:
cd gfx/video_filters
make
mkdir -p ~/.config/retroarch/filters/
cp *.filt *.so ~/.config/retroarch/filters/video
Now edit your config and change the video_filter_dir too
video_filter_dir = “~/.config/retroarch/filters/video/”
Then under video settings go to video filters and pick one
How do i access retro arch repo? Sorry im a total noob.
if you followed the guide…
it means from the retroarch dir, you ran:
git clone https://github.com/libretro/RetroArch.git retroarch
So if you did that it would be
cd ~/retroarch
thank you so much i did it! but where do i download the filters from? thanks
@Wizz @fr500 This is weird, ive done this before lots of times but this has never happened before. i added the emulator but games only load up from retroarch. when i try to play the game from the snes folder in games i get a black screen. i would appreciate any help, thanks
I don’t know anything about that launcher sorry
You don’t, the filters are the .filt files that were copied in this line:
Make sure you do this
video_filter_dir = “~/.config/retroarch/filters/video/”Then under video settings go to video filters and pick one
thanks i found the filters and wow the difference is amazing! but do i have to pick the filter every time or just once?
They are persistant across the cores and reboots is my experience ! Happy you got it working !!!
thank you wizz!
I do these steps exactly as above, starting in retroarch, and I get: cp: target ‘/home/cpi/.config/retroarch/filters/video’ is not a directory
what am I doing wrong?
from retroarch.
yep, did that in retroarch. What I did was find my way to the directory, and made the required directory there. then re tried the cp command and it worked that time.
change this
to
mkdir -p ~/.config/retroarch/filters/video
That’s great, thanks so much!
Is there anyone experiencing issues getting 32x to load? I have added the picodrive and the proper script, but when i attempt to run it, it returns to the Shell
- I have also added the BIOS file for SegaCD, just in case, but to no avail.
- I tried loading the picodrive Core manually from RetroArch, and load the content, but it leads to the same restart.
Hey man how do I turn the filter off? It’s screwing with my PCSX hard
Go back to the video filter option, but this time press start. It’ll restore it to default.
I got round to doing this yesterday. All installed fine now, thanks.
Trouble is, I get horrendous slow-down on just about every core with filters applied…
As a aside, is there an optimal setting to get genesis plus gx to run without stuttering?
I just realized that all the save files on my RetroPie can be transferred and played on my GS.
Not sure how many people know this, but it’s totally do-able, and I think that’s pretty freakin’ neato.
