Hola a todos por error formatie la microSD de mi clockworkpi y no se que hacer! Podeis ayudarme ya que no la puedo usar para nada
r043v
April 6, 2020, 9:22pm
2
hola, primero descargue la imagen de un sistema operativo, o mire la de @javelinface basada en el sistema oficial , o mi puerto arch linux , luego use el software etcher para flashear el sistema en su tarjeta sd
Hola, bienvenido a los foros.
Aquí hay algunas instrucciones sobre cómo flashear la imagen si es necesario.
Hey, I’ll just put a quick step baby step flashing guide up.
The file should be “clockworkos_v0.4.img.bz2” - when you download it, and is 1.67GB.
First, decompress the compressed file. You should get “clockworkos_v0.4.img” which is 7.95GB.
To make things easier, download an application to your mac, like Etcher. (It’s what I use) It’s what you use to flash file images to SD cards and USB cards safely. https://www.balena.io/etcher/
Once you have the program, select the image you…
En cuanto a los enlaces a las imágenes mencionadas, aquí están.
Hi GameShellers,
We are more than happy to announce that the Clockwork OS v0.5 is ready to go!
We are sincerely grateful for the support from the community. The creativity and concentration inspired us a lot. YOU GUYS ROCK!
[WeChat Image_20200104162852]
Download:
http://dl.clockworkpi.com/clockworkos_v0.5.img.bz2 ==> Mirror #1 ==> Torrent
md5sum: 27f85542d0278f898bfca060c264dc6f
(Updated. Fixed a few bugs found in this thread)
v0.5 latest release note:
1. Linux kernel is upgraded to …
Similar to my previous DEOT custom build based on 0.4 , I have put together a new image, based on the ClockWork OS 0.5.
This is the same as the official 0.5 image, just with a lot of updates, and quality of experience optimisations. You don’t need the DEOT edition Gameshell to use this. The official DEOT image is much older, and behind the official 0.5 image. This custom image is the bridge to get the best of both worlds.
[b7d679edaee7a55ad42147c9085b5e919824296a_2_462x500]
Here is a google dr…
Here come the beta release of my Arch Linux ARM port,
Feature :
Multitask
anywhere Volume / Backlight control
CPU actives Core number & Governor / Frequency selection
dedicated Launcher
multiple & native WI-Fi profiles
latest Mesa / Lima / Kernel / Retroarch …
dedicated Pacman binary repository
auto expand File System at first boot
Launcher, Fantasti, alpha revision
The fantasti is a Provencal elf, very close to the gripet, who establishes himself in the stables and then takes care of the c…
¡Buena suerte!
