Here come the beta release of my Arch Linux ARM port,
Feature :
Multitask
anywhere Volume / Backlight control
CPU actives Core number & Governor / Frequency selection
dedicated Launcher
multiple & native WI-Fi profiles
latest Mesa / Lima / Kernel / Retroarch …
dedicated Pacman binary repository
auto expand File System at first boot
Launcher, Fantasti, alpha revision The fantasti is a Provencal elf, very close to the gripet, who establishes himself in the stables and then takes care of the cattle
Fast, writed in C
File Explorer philosophy
System native file launch method
sub-process management
could upgrade all packages from dedicated repository
transparent ZIP support
OS Keys :
Menu is the Hotkey
Volume control with Menu + Left / Right
Backlight control with Menu + Up / Down
Window context switch with Menu + Select
Terminate current program with Menu + B
Restart Xsession with Menu + X
SSH :
default user is gs, with password gs root password is root
Fantasti Keys :
Menu to back, Start to enter
Explorer Keys :
Start to enter a directory
Start to launch a file
Select to go back a level
Menu to get out, will keep last position on next enter
Notes:
I put a bunch of public domain roms, tryed to keep all things legally, there may be any miss
You will for now need to reboot after created your WI-Fi profiles
Yaourt & Pikaur AUR helper are setup & fonctionnal
Mupen++ Retroarch Core don’t currently work with Lima, it miss shader functionality
Some things like Retroarch core are not for now from the repository and was Compiled & Setup in place
Native OS Open use xdg-open with the wrap of mimeopen, i set some roms file type to open with the good retroarch core, audio / video with mpv, pictures with feh, to create an association for an unhandled file use mimeopen -d “your file”
do system upgrade using sudo pacman -Syu by ssh, it will also upgrade all packages from custom repository, launcher update command will only do package from custom repo
do NOT push enter 10 times in file explorer to execute something, just be patient, will be limited in future
if a zip contain more than a file it will be show in explorer like a directory
if a zip contain a single file it will be uncrunch in /tmp and launched by the system
NO Bluetooth for now
still use clockwork u-boot
all the requirement for clockwork launcher are present (else wicd as we use netctl), system can launch clockwork launcher if you want
Future : Some, i wait for your return.
Setup
Minimal SD card is 8GB, OS take 5GB, Gzipped image is 1.6GB
never used it before, i initially used usb serial gadget,
checked, usb ethernet is enabled, but not configured,
you yet need type command from a terminal on the gameshell
for set a network with gs address at 10.0.1.1 :
sudo ifconfig usb0 10.0.1.1 netmask 255.255.255.0 up
and on my pc where usb eth show as enp0s26u1u2 device :
sudo ifconfig enp0s26u1u2 10.0.1.2 netmask 255.255.255.0 up
i will check automatic config on next release
i’ll try made a video :- )
edit > updated launcher to 0.4.h version, can now start usb ethernet with fixed ip 10.0.1.1 from network menu
you could update it directly from launcher update menu (with pressing enter for confirm the Y/n question)
Instead of using yaourt, I recommend using yay. Yaourt has several issues, and yay is the alternative to it. It was made to replace yaourt, and is supports every box in the comparison table. Yaourt has also been discontinued and cannot be found on the AUR itself.
tomorrow i’ll try make a video
don’t expect too much in graphic term, launcher is fully text & list based, not any icons at all,
philosophy is to be fast & efficient, giving you some control as primary goal
i shutdown multiple times each days without issues,
systemd may occasionally be a bit longer to unmount the partitions, as first boot extend partition it may want done a full fsck on shutdown ?
it also could be longer to shutdown if a process get stuck, if it is the case you will see rotating red stars *** with a timeout waiting the process exit before killing him
for now using launcher you could only connect to visible wpa networks,
as the launcher only create a netctl conf file in /etc/netctl/ you could manually create a dedicated file
in your case for a hidden network you must add a Hidden=yes line in your file (netctl.profile man)
just updated the launcher to 0.4.i, first entry of “scan wifi” result will now be “hidden network”, if selected it will asking you ssid to create the profile file,
still yet need to be a wpa network, and yet need having a network active to update the launcher using update menu entry
some are from the official repo, some compiled from AUR, i started make binary packages in my dedicated repo, there must be one or two core who still manually compiled
current snes core is pocketsnes, a prebuild binary package is on my custom repo, you could also found precompiled bsnes package but my last test wasn’t lucky
you could sudo pacman -U the package file or directly sudo pacman -S libretro-bsnes-gameshell
snes core(s) was the last platform who weren’t work, black screen at each core for an unknow raison, finally pocketsnes worked :- )
(real miss still n64, arm dynarec in mupen & parallel hang the system and each complain about shader functionality missing at init, force mesa to declare other GLES & GLSL wasn’t help
Extremely interesting!
Could you try FinalBurn Neo (ref.0.2.97.44) emulation with In The Hunt (inthunt.zip), Night Slasher (nslasher.zip), Ninja Baseball Bat Man (nbbatman.zip) and Attack of the lunar Loonies (spcinv95.zip) ? This will show right away if Arcade emulation is better.
Really digging the launcher! Really snappy and I haven’t run into any sort of crashing issue at all!
I have two questions.
Is there a way to set up an autostart script so that retroarch launches on boot?
I made the mistake of attempting to edit the mimekey.list to change default apps for gb and gbc (would really want to use gambatte for those, and possibly gpsp for gba if it is working). This ended up breaking it. Is there a way to get it working again?
