I would say that wireguard-modules package requires linux-image-rpi and it replaces clockworkpi-kernel
and running command
sudo apt install wireguard  linux-image-6.6.74+rpt-rpi-v8- linux-image-rpi-v8- linux-image-6.6.74+rpt-rpi-2712- linux-image-rpi-2712- linux-image-6.1.0-32-rt-arm64- linux-image-rt-arm64- linux-image-6.1.0-32-cloud-arm64- linux-image-cloud-arm64- linux-image-6.1.0-32-arm64-
Should install wireguard without replacing kernel (I just added - symbol to the end of each kernel package till it stop crying)
But I’m not sure that it will work and survive apt upgrade
Therefore I would say the best way is to make specific uconsole .deb, but I’m not qualified enough.
(theoretically, it should be enough to download .deb file, unpack it, modify control file by removing kernel dependency, pack it back and install)
The Raspberry Pi kernel in the control say it provided wireguard-modules They’re already built into my kernel so I’m adding it to the control file to test here in a bit. @mrbish I’ll let you know when to test. to test you’ll just need to reinstall the kernel. sudo apt update then sudo apt reinstall clockworkpi-kernel
Rex has been a huge help to us all, to which we are all very grateful I’m sure. :ok_hand:t2:
If you would like to show appreciation you can buy Rex a coffee:
Completely up to you and others of course but I know the time and effort he has saved me by sharing his efforts has been huge.
Thanks @Rex , it is much appreciated. You always take the time to answer questions and help out, even dumb questions like mine.
:+1:t2: :folded_hands:t2:
(I do not know Rex and he hasn’t endorsed this post. I hope I’m not breaking any rules).
Wireguard should install now without overwriting the kernel. Go ahead and run sudo apt update then sudo apt reinstall clockworkpi-kernel then reboot.
Oh my goodness @Rex you’re unbelievable. I literally wrote my post after just vaguely poking around the issue in a half-brained way in between actual work tasks on a home office day, had my dinner and went to bed. I woke up and while drinking my coffee I did an apt update, saw the new kernel version, started the apt upgrade without thinking and then, while it was installing, realised what it probably was and immediately installed Wireguard without a hitch.
Thank you so much, this is totally above and beyond: I frequently deal with contracted SaaS providers that are a thousand times less responsive and helpful than this, and adding together all the work you’ve done here, you’ve definitely saved me weeks at this point. @Talos is absolutely right, and I hope a few more people buy you a coffee.
Thank you and I appreciate the support! I’m happy it’s working for you now, glad I could help!
If i need to move this to the parrot forum let me know. I have no intention of highjacking this page. Update to my previous post: Parrot OS does still have the issue but also experienced it on the PI os version. CM5 lite, eeprom done, latest image, tried on both teampro sd card and sandisk pro. Parrot: play 4k youtube video and after approx 10 minutes sound stops, display goes blank. no response. have to force shutdown and reboot. turned off all power management settings. PI OS: very solid, after about an hour, power at approx 60%, cpu sitting at 43, browsing snap store for fun and display did the same. turned off no response, force shutdown and rebooted. checked all connections, etc. Not sure which direction to look at for diagnosis. Any ideas?
Kinda sounds like a battery problem. What batteries do you have and have they drained to 0% before?
Samsung 35E. I also saw the same issue when running a charger. After the reboot on pi os it was working again but I didn’t stay on it long. The batteries were close to zero when I received them. I would think if it was a battery issue then it would fail at an exponential rate after the first failure. All tests where done on the same cycle.
Considering the change in OS changed the rate in which it occurred I’m leaning that direction. But it feels more like a hardware issue.
The batteries can have a voltage drop when the CPU spikes, and cause a shutdown. A reboot will work but then another voltage drop will shut it down again. If you received them dead then that’s not good for the battery they could have been dead sitting for a while.
With my testing this morning it does seem to be when the GPU and CPU is at a high load. yeah, and I was pretty concerned when i recieved them almost dead… I will get ahold of some other batteries and try them out. Thank you for your help on this. Love the device, this just has my nerves in a bunch haha
hello and first of all thanks Rex! one question based on your experience, do you have any recommendations for batteries and SD Card that work really well, I just bought the Non core kit along with the CM5108000, thank you very much!
Hey there,
First thanks a lot for this build, but I have 2 questions, which I hope to find answers to:
  • latest 6.12 bookworm image works fine with CM5 4gb in uconsole, but not with CM5 8gb (on external screen I see kernel panic, while uconsole screen remains blank).
  • same 6.12 bookworm shows weird battery levels on both CM4 and CM5. It turns off at about 55-60% of battery left and then turns on only if I plug it to the wall.
    Any suggestion will be appreciated
you can try to recalibrate batteries: Bookworm 6.6.y for the uConsole and DevTerm - #164 by Rex
(or you can cycle them in external charger if you have one)
What are you seeing on the external screen? If its about not finding a SD card then check the OP for instructions on fixing it. it’s a known problem.
What batteries do you have? My go to batteries are the Samsung 35Es, calibrate the batteries or try some different ones.
I don’t remember the exact output, I will check it later today and provide the info, but it is not about SD card, as I’m using CM5 with emmc storage, which flashed with the bookworm image.
I have some generic 18650 batteries without any branding on them.
I tried this approach: Bookworm 6.12.y for the uConsole and DevTerm - #21 by Rex
but I don’t see any changes
Post the output of the CM5 when you get a chance.
Generic batteries are definitely the problem. You need good batteries, cheap batteries can have some bad voltage drop when under load and the uConsole does not handle it well.
are you running CM5 all the time? people above mentioned weird artefacts below 50% charge on CM5, may be you’ve drawn a lucky straw with your batteries: Bookworm 6.12.y for the uConsole and DevTerm - #205 by NumbaWon
