na it wasnt ur script, writeup bro
was my failure, i was not thinking correctly… so i didnt asume ur s would fuck with my games
dont worry i just know how to provoke u it seems haha sorry ;D
my workout is still goin on and on i will give u a dump later to night, sorry but i installed ur custom img and i also set it up again, i will try the script also later .
anyway i used mariokart, and it was not working with sfc files and the other one, does not matter , and the chmod thing also is not doing anything, strange., i am not sure why its not working with mine. maybe u could give me ur img without the games ofcourse if you dont mind, just ur doom game ;D i wanted to try that out too soo it would be a winwin for me D; i ll write later, and give u a heads up
thanks btw for ur efford and will to fix that sh…
Edit 1; image is on a second sd… and i ll try that out still my first main sd is with the vanilla
Edit 2:
I tried to run that sh file:
it didnt work…
how i did it:
I shh my cpi and put the game into /home/cpi/games/SNES
then i put the script thing into : /home/cpi/launcher/Menu/GameShell
after that i putty … with sudo chmod …
i run it … the script in the homemenu…
didnt help it just exited like the other times…
Edit 3 .
here is that log
[ 27.803]
X.Org X Server 1.20.4
X Protocol Version 11, Revision 0
[ 27.803] Build Operating System: Linux 4.9.0-8-arm64 armv8l Debian
[ 27.803] Current Operating System: Linux clockworkpi 5.7.0-clockworkpi-cpi3-g5c715d2cd-dirty #1 SMP Thu Jun 18 20:43:51 AWST 2020 armv7l
[ 27.804] Kernel command line: earlyprintk no_console_suspend fsck.repair=yes root=/dev/mmcblk0p2 rootfstype=ext4 rootwait init=/lib/systemd/systemd noinitrd panic=10 cma=256M
[ 27.804] Build Date: 05 March 2019 08:11:12PM
[ 27.804] xorg-server 2:1.20.4-1 (https://www.debian.org/support)
[ 27.804] Current version of pixman: 0.36.0
[ 27.804] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 27.804] Markers: (–) probed, () from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 27.805] (==) Log file: “/home/cpi/.local/share/xorg/Xorg.0.log”, Time: Tue Jan 5 22:05:32 2021
[ 27.825] (EE) Unable to locate/open config file: “~/launcher/.xorg_lima.conf”
[ 27.825] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[ 27.844] (==) No Layout section. Using the first Screen section.
[ 27.844] (==) No screen section available. Using defaults.
[ 27.844] () |–>Screen “Default Screen Section” (0)
[ 27.844] (**) | |–>Monitor “”
[ 27.846] (==) No monitor specified for screen “Default Screen Section”.
Using a default monitor configuration.
[ 27.846] (==) Automatically adding devices
[ 27.846] (==) Automatically enabling devices
[ 27.846] (==) Automatically adding GPU devices
[ 27.853] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 27.873] (WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
[ 27.873] Entry deleted from font path.
[ 27.896] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/100dpi/:unscaled,
/usr/share/fonts/X11/75dpi/:unscaled,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
built-ins
[ 27.896] (==) ModulePath set to “/usr/lib/xorg/modules”
[ 27.896] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 27.896] (II) Loader magic: 0x5b4f98
[ 27.896] (II) Module ABI versions:
[ 27.896] X.Org ANSI C Emulation: 0.4
[ 27.897] X.Org Video Driver: 24.0
[ 27.897] X.Org XInput driver : 24.1
[ 27.897] X.Org Server Extension : 10.0
[ 27.902] (++) using VT number 1
[ 27.912] (II) systemd-logind: took control of session /org/freedesktop/login1/session/c1
[ 27.917] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 27.921] (II) systemd-logind: got fd for /dev/dri/card1 226:1 fd 11 paused 0
[ 27.927] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 27.930] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 12 paused 0
[ 27.931] (II) no primary bus or device found
[ 27.931] falling back to /sys/devices/platform/display-engine/drm/card1
[ 27.931] (II) LoadModule: “glx”
[ 27.935] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 28.036] (II) Module glx: vendor=“X.Org Foundation”
[ 28.036] compiled for 1.20.4, module version = 1.0.0
[ 28.037] ABI class: X.Org Server Extension, version 10.0
[ 28.037] (==) Matched modesetting as autoconfigured driver 0
[ 28.037] (==) Matched fbdev as autoconfigured driver 1
[ 28.037] (==) Assigned the driver to the xf86ConfigLayout
[ 28.037] (II) LoadModule: “modesetting”
[ 28.038] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 28.044] (II) Module modesetting: vendor=“X.Org Foundation”
[ 28.044] compiled for 1.20.4, module version = 1.20.4
[ 28.044] Module class: X.Org Video Driver
[ 28.044] ABI class: X.Org Video Driver, version 24.0
[ 28.044] (II) LoadModule: “fbdev”
[ 28.045] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 28.059] (II) Module fbdev: vendor=“X.Org Foundation”
[ 28.059] compiled for 1.20.4, module version = 0.5.0
[ 28.059] Module class: X.Org Video Driver
[ 28.060] ABI class: X.Org Video Driver, version 24.0
[ 28.060] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 28.060] (II) FBDEV: driver for framebuffer: fbdev
[ 28.060] (II) modeset(0): using drv /dev/dri/card1
[ 28.061] (WW) Falling back to old probe method for fbdev
[ 28.061] (II) Loading sub module “fbdevhw”
[ 28.061] (II) LoadModule: “fbdevhw”
[ 28.061] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 28.064] (II) Module fbdevhw: vendor=“X.Org Foundation”
[ 28.064] compiled for 1.20.4, module version = 0.0.2
[ 28.064] ABI class: X.Org Video Driver, version 24.0
[ 28.064] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[ 28.065] (II) modeset(0): Creating default Display subsection in Screen section
“Default Screen Section” for depth/fbbpp 24/32
[ 28.065] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[ 28.065] (==) modeset(0): RGB weight 888
[ 28.065] (==) modeset(0): Default visual is TrueColor
[ 28.065] (II) Loading sub module “glamoregl”
[ 28.065] (II) LoadModule: “glamoregl”
[ 28.066] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 28.191] (II) Module glamoregl: vendor=“X.Org Foundation”
[ 28.191] compiled for 1.20.4, module version = 1.0.1
[ 28.191] ABI class: X.Org ANSI C Emulation, version 0.4
[ 28.668] (II) modeset(0): glamor X acceleration enabled on Mali400
[ 28.668] (II) modeset(0): glamor initialized
[ 28.675] (II) modeset(0): Output None-1 has no monitor section
[ 28.675] (II) modeset(0): EDID for output None-1
[ 28.675] (II) modeset(0): Printing probed modes for output None-1
[ 28.676] (II) modeset(0): Modeline "320x240"x59.8 5.80 320 326 328 388 240 242 244 250 +hsync +vsync (14.9 kHz eP)
[ 28.676] (II) modeset(0): Output None-1 connected
[ 28.676] (II) modeset(0): Using exact sizes for initial modes
[ 28.676] (II) modeset(0): Output None-1 using initial mode 320x240 +0+0
[ 28.676] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[ 28.676] (==) modeset(0): DPI set to (96, 96)
[ 28.676] (II) Loading sub module “fb”
[ 28.676] (II) LoadModule: “fb”
[ 28.687] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 28.693] (II) Module fb: vendor=“X.Org Foundation”
[ 28.693] compiled for 1.20.4, module version = 1.0.0
[ 28.693] ABI class: X.Org ANSI C Emulation, version 0.4
[ 28.694] (II) UnloadModule: “fbdev”
[ 28.694] (II) Unloading fbdev
[ 28.694] (II) UnloadSubModule: “fbdevhw”
[ 28.694] (II) Unloading fbdevhw
[ 28.998] (==) modeset(0): Backing store enabled
[ 28.998] (==) modeset(0): Silken mouse enabled
[ 29.018] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[ 29.024] (==) modeset(0): DPMS enabled
[ 29.029] (II) modeset(0): [DRI2] Setup complete
[ 29.029] (II) modeset(0): [DRI2] DRI driver: sun4i-drm
[ 29.029] (II) modeset(0): [DRI2] VDPAU driver: sun4i-drm
[ 29.029] (II) Initializing extension Generic Event Extension
[ 29.031] (II) Initializing extension SHAPE
[ 29.033] (II) Initializing extension MIT-SHM
[ 29.036] (II) Initializing extension XInputExtension
[ 29.038] (II) Initializing extension XTEST
[ 29.046] (II) Initializing extension BIG-REQUESTS
[ 29.047] (II) Initializing extension SYNC
[ 29.048] (II) Initializing extension XKEYBOARD
[ 29.049] (II) Initializing extension XC-MISC
[ 29.050] (II) Initializing extension SECURITY
[ 29.050] (II) Initializing extension XFIXES
[ 29.051] (II) Initializing extension RENDER
[ 29.052] (II) Initializing extension RANDR
[ 29.054] (II) Initializing extension COMPOSITE
[ 29.054] (II) Initializing extension DAMAGE
[ 29.055] (II) Initializing extension MIT-SCREEN-SAVER
[ 29.056] (II) Initializing extension DOUBLE-BUFFER
[ 29.057] (II) Initializing extension RECORD
[ 29.058] (II) Initializing extension DPMS
[ 29.058] (II) Initializing extension Present
[ 29.059] (II) Initializing extension DRI3
[ 29.060] (II) Initializing extension X-Resource
[ 29.061] (II) Initializing extension XVideo
[ 29.062] (II) Initializing extension XVideo-MotionCompensation
[ 29.062] (II) Initializing extension SELinux
[ 29.062] (II) SELinux: Disabled on system
[ 29.062] (II) Initializing extension GLX
[ 29.063] (EE) AIGLX error: sun4i-drm does not export required DRI extension
[ 30.646] (II) IGLX: Loaded and initialized swrast
[ 30.646] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[ 30.647] (II) Initializing extension XFree86-VidModeExtension
[ 30.647] (II) Initializing extension XFree86-DGA
[ 30.648] (II) Initializing extension XFree86-DRI
[ 30.648] (II) Initializing extension DRI2
[ 30.659] (II) modeset(0): Damage tracking initialized
[ 30.659] (II) modeset(0): Setting screen physical size to 84 x 63
[ 31.258] (II) config/udev: Adding input device rancidbacon.com UsbKeyboard (/dev/input/event1)
[ 31.258] () rancidbacon.com UsbKeyboard: Applying InputClass “libinput keyboard catchall”
[ 31.258] (II) LoadModule: “libinput”
[ 31.258] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 31.343] (II) Module libinput: vendor=“X.Org Foundation”
[ 31.343] compiled for 1.20.4, module version = 0.28.2
[ 31.344] Module class: X.Org XInput Driver
[ 31.344] ABI class: X.Org XInput driver, version 24.1
[ 31.344] (II) Using input driver ‘libinput’ for ‘rancidbacon.com UsbKeyboard’
[ 31.347] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 24 paused 0
[ 31.347] () rancidbacon.com UsbKeyboard: always reports core events
[ 31.347] () Option “Device” “/dev/input/event1”
[ 31.348] () Option “_source” “server/udev”
[ 31.429] (II) event1 - rancidbacon.com UsbKeyboard: is tagged by udev as: Keyboard
[ 31.429] (II) event1 - rancidbacon.com UsbKeyboard: device is a keyboard
[ 31.437] (II) event1 - rancidbacon.com UsbKeyboard: device removed
[ 31.437] () Option “config_info” “udev:/sys/devices/platform/soc/1c1a400.usb/usb2/2-1/2-1:1.0/0003:4242:E131.0001/input/input1/event1”
[ 31.437] (II) XINPUT: Adding extended input device “rancidbacon.com UsbKeyboard” (type: KEYBOARD, id 6)
[ 31.437] () Option “xkb_model” “pc105”
[ 31.437] () Option “xkb_layout” “us”
[ 31.447] (II) event1 - rancidbacon.com UsbKeyboard: is tagged by udev as: Keyboard
[ 31.448] (II) event1 - rancidbacon.com UsbKeyboard: device is a keyboard
[ 31.458] (II) config/udev: Adding input device axp20x-pek (/dev/input/event0)
[ 31.458] () axp20x-pek: Applying InputClass “libinput keyboard catchall”
[ 31.458] (II) Using input driver ‘libinput’ for ‘axp20x-pek’
[ 31.461] (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 27 paused 0
[ 31.461] () axp20x-pek: always reports core events
[ 31.461] () Option “Device” “/dev/input/event0”
[ 31.461] () Option “_source” “server/udev”
[ 31.467] (II) event0 - axp20x-pek: is tagged by udev as: Keyboard
[ 31.467] (II) event0 - axp20x-pek: device is a keyboard
[ 31.467] (II) event0 - axp20x-pek: device removed
[ 31.468] () Option “config_info” “udev:/sys/devices/platform/soc/1f03400.rsb/sunxi-rsb-3a3/axp221-pek/input/input0/event0”
[ 31.468] (II) XINPUT: Adding extended input device “axp20x-pek” (type: KEYBOARD, id 7)
[ 31.468] () Option “xkb_model” “pc105”
[ 31.468] () Option “xkb_layout” “us”
[ 31.480] (II) event0 - axp20x-pek: is tagged by udev as: Keyboard
[ 31.480] (II) event0 - axp20x-pek: device is a keyboard
[ 32.059] (II) modeset(0): Disabling kernel dirty updates, not required.
