Found my original .4 version and ran that and everything runs fine on that so it’s not hardware. A plus on all of them PlayStation one runs fine doing runs fine it’s just the retroarch stuff doesn’t run fine, however on .4 (my original 64 gig card I was using) retroarch is also acting weird but I never got that working right on that one
Try making an image of your working SD card, then writing it to the one you were using for 0.5 that didn’t behave. From what I recall re: some of your previous posts, you’ve had troubles with SD cards in the past. You can only read/write to them a finite number of times, and doing a complete image overwrite uses up a lot of those lives. SD Cards care super cheap. Given that this is essentially a hacking device, it will give you a much better quality of life experience having multiple cards, and buying new ones to troubleshoot with, when things like this stop working.
That said, the fact that everything besides retroarch works makes me wonder what is going on.
Is there ANYTHING that you have changed on the image? I’m talking, small settings you don’t even think are relevant, like changing a theme in retroarch, editing a config, files you tried to move onto it when on your linux machine, even changing the date etc.
wasnt me with the sd issues I dont think, I think I narrowed it down to the retroarch on my deot card, everything on it outside retroarch works normally, anything in retroarch (including moving in retroarch menus) is VERY slow, never made changes to it, was quite happy with how it was working
Great, so did you change anything at all? Is this on a fresh image? Are you using the XMB interface? I need a bit of information to help you here.
If indeed it’s not hardware related, theoretically it should be happening on my machine too.
And if your old 0.4 image worked fine, then something has definitely changed on your end.
Like literally, anything you’ve changed as small as you think it might be could be the culprit.
Edit: oh hang on, you said you never got retroarch working on your original 0.4 card either. Right. Lets try and find out what you have changed. Please?
was using XMB but til yesterday had no issues with it, not til I tried the .5 (on another new sd), after looking at the .5 clockwork os, I put my deot back in and thats when the issues started, again, only things using retroarch
Right. So can you tell me what settings you have changed in retroarch? I can’t really help you unless I know what has been changed on your end, besides putting a new SD card in. Unless you somehow managed to flash an EEPROM between changing cards (you couldn’t have unless you knew you were doing it), there should not have been anything that could have changed, just changing an SD card. The only other thing I can think of is that you have jiggled a cable loose/frayed or something similar.
Also, can you please test things using a freshly flashed SD card?
thats just it, aside from setting XMB I didnt change anything, loaded cores in retroarch is all
plus is I frayed a cable, the original .4 sd would also have the issues
With the newer lima drivers, and proper implementation of the GPU, there could be an increased demand in a consistent current; hence why I was wanting you to double check the cable integrity.
Have you tried flashing a fresh image? If you haven’t changed anything, then theoretically it should be the same. If you don’t want to do that, then I guess try and overwrite the retroarch configuration file with the one I put together.
ill try that, im short on sd cards right now and on a budget for a few weeks lol, where do I paste your cfg?
I mainly pasted it here so you could compare it to your own to see what you have changed.
This is where the config is stored:
./config/Retroarch/retroarch.cfg
It might just be easier for you to copy paste it from here, if you didn’t want to find out what was wrong. It would be useful if you did though, since this will be good information to help other in the future.
https://drive.google.com/open?id=1xjuLFPvbtcq3FDDYCX-GI1wTCXX4XB7n
oh ok, i’ll take a look then, ill be back in a bit
im an idiot, cant figure out how to get to the cfg file for retroarch, using winscp
Could you perhaps start a new thread? This is clogging things up here and COMPLETELY off topic.
oh sure, sorry bout that
And back on topic, here is a modified skin file that corresponds to the file structure of the 0.5 official image. It also substitutes some of the thematic icons to take the place of items that would otherwise be blank:
https://drive.google.com/open?id=1wEH8P9faECjj6glUlRWQkSsSyWo0FjQW
Decompress the DEOT.zip folder, and drag it into the skins directory.
If you want the extra edge lord hacker thematic files from the DEOT OS (they’re actually just for show), then decompress the “Extra Icons.zip”, select the individual folders and copy them to ~/launcher/Menu/Gameshell.
The font of the DEOT is a custom one, and if you want it you’ll have to specify it. I don’t know any better way to do it other than replacing the skin manager, but I’m working on it. Let me know if you know.
In the skin manager directory in my shared folder, there are two files: skin_manager.py and skin_manager.py.bak. The first one is the DEOT version, with paths leading to the fonts. Copy this over the existing one, found in ~/launchersys.py/UI/
If you want to her revert to the original one, skin_manager.py.bak is a backed up copy. Just remove the .bak extension and copy it over.
There are some extra fonts found in the truetype.zip file. Decompress this, and copy them to ~/launcher/skin/default/truetype
There are a few items in the settings menu that are different in DEOT OS; Airplane, Brightness, ButtonsLayout, Sound and Storage. Decompress settings.zip, and copy the individual folders into ~/launcher/Menu/GameShell/10_Settings. Likewise, Tiny Cloud looks slightly different in DEOT. DO the same thing, just copying to ~/launcher/Menu/GameShell. This will overwrite all of the above, so make backups if you intend on restoring them ever.
That should be most of the DEOT features copied over. Unfortunately, the clean cut minimalistic icon layout has had to be cut, if I wanted to have this theme match up to whatever the 0.5 official firmware uses.
Now! Onto preferences for the new theme! Feel free to vote for as many as you want. This is just to get an idea of what to do for the future release that is coming up soon.
- Would you want me to include the DEOT Fonts?
- Would you like to be able to revert back to the stock 0.5 white theme?
- Do you want to include the OP-1 theme?
- Do you care about the edge lord hacker apps?
- Would you want me to make more icons to match the DEOT theme?
- Does having a custom boot/loading screen via an edited kernel appeal to you?
- Do you even care about the DEOT theme?
- Would you want to have a custom launcher icon layout chooser?
- Do you even use the Hexen/Heretic/Strife wad wrappers?
- Is having a remove mail script useful for you?
- Do you care about having global volume control, ie in standalone emulators etc?
- Was having all of the cores pertaining to retroarch moved to the ./config/Retroarch/cores directory (instead of applications/emulators) something that was useful?
- Does having all retroarch features (eg, XMB interface) appeal to you?
In other news, all of the features in this post have now been implemented. Surprise! Retroarch 1.8.2 is installed on it!
I am just testing the image and polishing it up around the edges a bit. Let me know if anyone would like me to upload an incomplete beta version for testing, and reporting back. Note: It WILL be buggy! ![]()
Happy new year! Just released DEOT v2.0+
Could someone upload the DEOT to a torrent so ppl can actually download it without it being too big and windows blocking it and not scanning it and therefore it wnt complete the download
i finally realized its not even completing the dl just freezing and 0 b/s at the end… no wonder my images didnt work and i spent all that time on wifi power settings and flashing images
Torrenting and seeding aren’t easily doable from my country without proxies. They will be far slower than anything currently hosted. Sorry.
Hi! I burned the 191111 version of the image to a 64GB card, but I can’t run PCSX with the PSX bios. I already put it on /home/cpi/apps/emulators/bios but it didn’t work, PCSX still loads HLE bios.
Thanks in advance!
Oooh. Don’t use that version. It’s from 2019. It’s ridiculously old. The newest version has everything plus more. If you have flickers, just change the kernel with the utilities.
