Hi, probably better to not thread jack this with a post explaining how to apply everything. That said, in the original post, I have provided links to all of the threads in this forum that describe how to apply them all individually. I’ll provide some links below.
In particular, you will need to install a new kernel. Don’t forget to backup before applying this:
Then afterwards, follow this post from this thread. You’ll need go build it yourself:
(Just modify some of the code with this)
I’m not sure what you’re planning on using the new Lima drivers for, but one thing it works great with is the mupen64plus emulator. You’ll need go build it yourself:
Ive tried to make this thread both a culmination of a lot of things that people may have trouble doing, or simply can’t be bothered doing. It also serves the purpose as a means of self education, with links and sources to all features applied. If there’s anything in particular that you have in your setup that could be something I could add to this release, let me know! Perhaps I could make this image cater to your needs! ![]()
